Sponsored by: CARiD
Upper Ball Joint
Old Feb 3, 2009 | 06:01 PM
ranorris2's Avatar
Upper Ball Joint
I can't seem to get a good answer out of anyone yet...so im hoping this is the right place to ask:
Do I have to buy upper control arms if I am just needing ball joints or can I just get ball joint replacements? It seems to me I could "just" replace the ball joints, but some peeps have said I have to buy the upper control arm with the BJ's built in.
If someone could, please clear this up for me
Old Feb 3, 2009 | 06:12 PM
che22879's Avatar
From what I've searched you have to buy the control arm!
Old Feb 3, 2009 | 06:20 PM
fx4_613's Avatar
ya you have to buy the whole assy. i checked at napa auto parts today
Old Feb 3, 2009 | 06:29 PM
minimonster17's Avatar
no, you don't have to buy the new arm. you can press new ball joints into the old arm, but the UCA does have bushings on it that are prone to dry rot, so it is better to replace w/ a new arm.
Old Feb 3, 2009 | 07:07 PM
mnponds's Avatar
I just did this on Sunday. You need to replace the entire upper control arm. Only upside is that if you get the Moog UCA's, they come with a grease fitting.
Old Feb 3, 2009 | 08:25 PM
BIGCITYSLIDER's Avatar
if they are original control arms u have to buy whole arm with ball joint on it after that u can just replace the ball joint when needed rockauto.com has them for $96 lower one about $40
Old Feb 4, 2009 | 07:53 AM
DIHLON's Avatar
I asked this same question on the guy asking about lower ball joints: Are you changing both the uppers and the lowers? If not, how do you know which ones are bad? I have one squeeking horribly but I can't tell which one it is so I just grease them all but i'm wanting to replace them since greasing just temporarily fixes it.
Old Feb 4, 2009 | 10:55 AM
mason07's Avatar
when you rock the tire from top to bottom which end gives? that'll let ya know
and a temporary way that can sometimes help with the squeak is try to find a needle for a grease gun and pop it through the boot and fill it up
Old Feb 4, 2009 | 12:19 PM
DIHLON's Avatar
Nothing appears to be loose when I try to move the wheel from top to bottom. That's how i've been greasing them but it doesn't last too long.
Old Feb 4, 2009 | 12:28 PM
wandell's Avatar
If one is bad, rest assured the other 3 are not far behind.
Old Feb 4, 2009 | 04:00 PM
agree wandell change them all it only about 250 bucks in parts and u can do it urself for free just rent a ball joint press from autozone for the lowers
Old Feb 4, 2009 | 04:03 PM
u can also loosen the nut on the ball joint on the upper and grab the rod if it moves easily or loose at all u need new ones they are suppose to be real tight
Old Feb 5, 2009 | 06:19 PM
f150fella08's Avatar
they must have been changed already if they have grease zerks on them the factory ones dont have greasable zerks
Old Feb 5, 2009 | 07:11 PM
DIHLON's Avatar
I use a grease gun with a needle fitting to grease them. They don't have grease fittings.
Old Feb 5, 2009 | 10:42 PM
soo what do you do poke holes in the rubber boot??
