'05 F150 Lower Ball Joint replacement
your local auto store should have a tool that is basically a C-clamp with a hole on the end thats made for removing them. just jack it up, pull the tire off and use that tool to pop it out and press in the new one, and when you tighten the nut it'll pull whats left if there is any, kinda like pressin a new stud in a hub. thats about the basics of it
Ford dealership let me know about mine
How much more to you need to take off to get the lower bj out? Haynes manual just said that the lowers were non-serviciable and you need to replace the entire control arm. Which is bs. I have the exact same question jkubek
I think you have it backwards. The lowers can be replaced. The uppers you have to buy the entire control arm.
