Upper Control Arms / Ball Joints
Do any of you guys with a 6" lift have an aftermarket upper control arm? The reason i am asking is my upper ball joint is at a severe angle and I already need to replace them. I didnt know if there is an upper control arm out there made for lifted trucks that i could purchase and fix the ball joint angle or if I will have to keep replacing ball joints...
Thanks,
Ryan
Thanks,
Ryan
I haven't found a company that makes a "dropped" upper control arm for lifted F150's but I do know of 2 companies that make very strong uniball fitted tubular UCA's. Total Chaos http://www.chaosfab.com and Camburg http://www.camburg.com. Those 2 companies sell nearly identical products. Although your joints will still have extreme angles, the ball joint itself is larger and stronger than oem UCA's. FX4life has a set of Camburgs on his truck with an 8" Rize bumped up to 10" which is essentially the same as a 6" lift bumped up to 8". I just ordered a set of Total Chaos UCA's along with a Rize 8" that will be pushed to 10". I'll post some pics when I get them on.
