Sponsored by: CARiD
leveling kit help
Old Jan 31, 2009 | 04:11 PM
2wd98f150's Avatar
leveling kit help
who has put the rough country leveling kit(coil springs) on a 97-03 2WD f150? i want to talk to someone has this on there truck.
Please get back to me if you have. i have a question
Old Feb 27, 2009 | 05:39 PM
HerbalistF150's Avatar
I have these springs sitting on the floor on my front room- I an getting ready to put them in this sunday- I didn't like the way rough countrys website said these were 100% bolt on- When I got them the instructions say that you have to grind the triangular bump stop off the upper control arm to allow the control arm to come down further-
Old Feb 27, 2009 | 05:51 PM
madmaxwell87's Avatar
i havent put this exact kit on but ive pulled the suspension in and out on two of my trucks to intall coil spring spacers and spindle lifts etc. whats your question, i might be able to help.
Old Mar 4, 2009 | 08:12 AM
2wd98f150's Avatar
well i want to bring the rear end up and inch or 2 because those springs have it sitting a good 2 in higher in the front. i know they will break in and settle so i want to put blocks on the rear. if i want 1 to1 1/2inches of lift how big blocks should i buy?
Old Mar 4, 2009 | 01:50 PM
how big of lift springs did you put in cause normaly our trucks are about 1.5" higher in the back stock so youd have to have lifted the truck a good 3.5"s when the most you can do without aftermarket control arms is 2"s. as for the block im 98% positive its a direct ratio ie a 2" block lifts the back 2"s
Old Mar 8, 2009 | 04:05 PM
Finally put them on-
I finally put those rough country 2 inch leveling springs on- My truck is a 1999 2WD SuperCab 5.4- The front end looks like it's sitting just a hair taller than the back- I kind of like it tho- But putting another inch in the back probly wouldn't be a bad idea-
Old Apr 14, 2009 | 04:37 PM
2wd98f150's Avatar
what size shocks did you put on? stock?
Old Apr 18, 2009 | 11:26 AM
2wd98f150's Avatar
do you have pictures of your truck with the springs
