Sponsored by: CARiD
need a little help
Old Jan 30, 2009 | 08:10 PM
d4life45's Avatar
Exclamation need a little help
I have a 7.5 inch fabtech and a 3 inch body lift. im adding a 1.5 inch coil spacer and 1.5 inch AAL. my question is will it cause wear and tear on my tires and will it cause my tires to tilt inward? also my truck should be leveled right? thanks for your help.
Old Jan 30, 2009 | 10:10 PM
wandell's Avatar
The coilspring spacers will throw off your alignment. If you don't get it aligned, yes your tires will wear out.
Also, the spacers and AAL should lift the front and rear about the same amount.
Old Jan 31, 2009 | 01:59 AM
d4life45's Avatar
alright thank you for your help!
