fit 35's
fit 35's
I got a 2001 sport F150 that is two wheel drive. With a 3' body lift and a 3.5' spindle lift kit with the 2' rear blocks, would it be possible to fit 35's without them poking out on the sides of the fenders (anybody have pics)? and if so, what is the tire ratio with a 17" wheel. and is it possible to use the factory wheels with 35's or will they not fit? Thanks.
Since you have a 4x2, how much the tire/wheel sticks out up front will depend on how much your lift spindles increased your front track width. Some increase the track width more than others. You should be able to fit 35x12.50's (315/70-17) using your oem wheels or an 8 inch wide wheel with 4.5 inches of backspacing. You may also be able to use a 17x9 with 5 inches of backspacing.
