What size leveling kit recommended?
I have a 2005 F150 Lariat 4X4 Stock 18 wheels with Bridgestone Dualers
What advice would you have for the size of leveling kit? New to leveling kits so not sure whether 2 or 2.5 or some other size is best.
Thanks.
Thanks.
Use the search function. Basically people are going to say the bigger you go, the worse the angles are. Alot of people are running 2.5" leveling kits, because it makes you level. A 2" with have a slight rake. As for brand, A ton of people on here are running autospring. I personally have a 2.5" Daystar and love it. Good Luck
dude go with the 2.5; its the biggest size you can get without damaging your oem parts like ball joints. with a 3" you will get into some extreme angles and wear them out pretty quick and a 2" just doesnt seem to cut it imo. 2.5 is the way to go! i prefer AutoSpring or Daystar.
