Sponsored by: CARiD
skyjacker or fabtech
Old Jan 26, 2009 | 11:22 PM
wideopenthrottl's Avatar
i have a 2001 ford f150 off road 4x4 and want to lift it. i want to do a 6" suspension and 3" body later but fornow jsut the suspension lift. the only mkes i can find that have an actual 6" lift is skyjacker and fabtech which one do u think would be best. im pretty sure both kits have blocks for the rear abnd everything to lift the front exactly 6 inches without touching the torsion bars.
Old Jan 26, 2009 | 11:33 PM
4.2trimble's Avatar
Fabtech hands down.
I believe they are both true 6" lifts
Old Jan 27, 2009 | 09:11 AM
minimonster17's Avatar
fabtech. the skyjacker kit is ok, but the crossmembers are flat designed, whereas the fabtech's are arched, and therefore a more preferred design.
i'm not sure on the skyjacker, but the fabtech is a true 6'' lift. the subframe places the boltholes for the lower control arms a full 6'' below stock, and the rest of the kit is designed around this. the torsion bars, front differential, etc are dropped down to compensate for the lift.
Old Jan 27, 2009 | 10:14 AM
mhockey9090's Avatar
Yeah i have a 6 inch skyjacker on my truck rigth now and dont have any problems what so ever with it but its also a true 6 inch lift on mine atleast for my year
Old Jan 27, 2009 | 03:31 PM
c-huck's Avatar
you should contact national 4wd , great service for us canadian's.... i bought my fabtech through them ....they have 5 or 6 shops all over canada
Old Jan 27, 2009 | 03:41 PM
floorit's Avatar
between the 2 i would go with fab tech,,but im going to get a rough country. it has the best looking cross member IMHO
Old Jan 27, 2009 | 04:48 PM
c-huck's Avatar
the rough country looks like the pro-comp stage 1 but with a better looking cross member.IMO . It is one of the cheapest priced kits out i think also.
Old Jan 27, 2009 | 05:14 PM
4.2trimble's Avatar
and its not gonna hold up like a Fabtech.
Ive broken 2 Rancho lifts. Not on my F150 but 1 on my ranger and one on my bronco II
That was the last time i will use their lifts.
Things have changed though, and id trust rancho on the 04-08 but not on the 97-03.
the torsion bar front end is just too picky
Old Jan 28, 2009 | 01:35 PM
wingman4's Avatar
Did Ford keep using the torsion on the Rangers after 03? My buddy has an 04 (I think its an 04) and it has torsion bars, but it is a 2wd, so I dunno... Just curious.
Old Jan 28, 2009 | 04:19 PM
mason07's Avatar
the 4wd and the edges still use torsion bars on the rangers
and the reg 2wd still uses SLA with coils
Old Jan 28, 2009 | 09:43 PM
wingman4's Avatar
gotcha... Thanks!
Old Feb 6, 2009 | 06:04 PM
Nemisus's Avatar
Hardly comparable! The F150 lifts are NO way near the poor quality Rancho put out for RBV's! Those lifts are garbage!
I do believe they have since solved the issue of a drop plate vs new Bracket on the RBV though... but definately not my choice for RBV's!
With that out of the way.... you a member of broncoii.org? Should check it out if your not..... and if you still have the BII
Cheers
Nem
Old Feb 6, 2009 | 07:12 PM
4.2trimble's Avatar
Cheers
Nem
nah my BII was stolen, and the Ranger was givin to my sister, then sold. But i think im gonna buy it back.
And yes its not the same suspension but IMO i wont ever run their lifts again. thats just me. I know the TTB's were a pain in the butt to lift to begin with but after i went to a sky jacker lift i stopped breaking drop down brackets....
After so much headache from those companies ill spend my money else where.
Old Feb 6, 2009 | 07:55 PM
floorit's Avatar
im not trying to be a butt hole but who said anything about rancho. i was talking about a rought country
Old Feb 6, 2009 | 07:59 PM
4.2trimble's Avatar
yes and i said in my first post that i have totally destoryed Rancho, Rough Country, lifts.... then someone asked about the rancho .
they are very similiar kits.
do what you want man.But id save the money and get a Fabtech.
