Sponsored by: CARiD
6" pro comp+2.5" spacer...will it work
Old Jan 22, 2009 | 05:45 PM
04b&glariat4x4's Avatar
Hey due to uncle sam's generosity ill be gettin back a nice chunk of change this year. I already have a 2.5 spacer on the front and i was wondering..if i bought the 6in lift..could i stack the 2.5 spacer on top for more lift? Would there be any problems doing this? Thanks
Old Jan 22, 2009 | 06:13 PM
°°Pat°°'s Avatar
Yes you could, but you better go with a stage 2.
Stalking spacer isn't a great idea.
Old Jan 22, 2009 | 06:18 PM
MercedesTech's Avatar
yes, it can work.
Agree with Pat on that one, but you could get by stacking spacers. People do. Even a few on this site IIRC.
Old Jan 22, 2009 | 06:25 PM
so your saying i would need a lift with extended struts and springs instead of the big a-- spacer that the stage 1 procomp uses?
Old Jan 22, 2009 | 06:31 PM
ugacoop16's Avatar
nah I have stacked them together and I have the pro comp stage 1 kit.
Old Jan 22, 2009 | 06:32 PM
Shepard69's Avatar
Please post this in the "aftermarked - suspension forum" you will get better answers. This is the OEM Forum
Old Jan 22, 2009 | 07:00 PM
fx4 for life 79's Avatar
if you go with the basic fabtech you will be fine
He's getting plenty of help.
No, saying I would SUGGEST it. It would = a better ride, and just a better all around system. Stacking front spacers isn't as big of a deal as the rear. The only thing i don't like, is instead of one solid coilover mounted to a spacer, you have a spacer, mounted to coilover, mounted to spacer. Not the most solid, but it should be just fine. Run that way for awhile, and save up for some aftermarket coilovers !
How much off roading you plannin to do ? Abusive ? baby it ?
Old Jan 22, 2009 | 07:01 PM
all around better option if you ask me. Never been a huge fan of the pro comp lift.
Old Jan 22, 2009 | 09:25 PM
[QUOTE=MercedesTech;3548944]
Thanks for that...
As far as off-roading. Dirt roads..some snow(as much as we get in sc) is about it. Im not much into mudding in my truck. But never really ragging it out. Ive got a 4wheeler for that. Its alot cheaper to fix. So you say go with the fabtech...know where the best deal is?
Old Jan 23, 2009 | 08:39 AM
its good for the street but i wouldnt want to do any serious offroading with it
Old Sep 25, 2009 | 11:41 PM
sampson01's Avatar
Raising this thread from the dead but I have a 6 inch procomp but I had 3 inch HBS lvl kit on before do you think I could run my spacer with the strut extension and an add a lead in the rear or is that pushing it. And also wanna run a 3 inch bl later after the winter. Could this be possible with the front end geometry??
Old Sep 26, 2009 | 11:57 AM
vegas08f150's Avatar
people say not to run a 3". i have the 6" fabtech with a 2 1/2" spacer and im not sure you can even get a 3" in there. i had to fight to get mine in and bolted back up.
Old Sep 27, 2009 | 02:15 PM
IH8ATTN's Avatar
really?....I am thinking if using a 2" spacer up front. I don't want my CV's to be totally outta whack, in your case that isn't a problem.
Old Sep 27, 2009 | 06:00 PM
well im 2wd so i dont have any cv's. my balljoint angles arent any more messed up than every person out there just running a regular leveling kit with no lift.
