Sponsored by: CARiD
My Airbag/onboard air setup (Warning! Lots of Pics!)
Old Feb 13, 2009 | 02:59 AM
Stephen87's Avatar
ahh I see said the blind man to his deaf wife while peeing into the wind,"it's all coming back to me now."
anyways nice set up only thing I would change about it is to have a on board compressor, however I would leave the part to fill the tank with a compressor so that if the compressor stops working I can use that and also so I can use some air tools or fill the tires on my trailer with air while I am at the ranch
Old Feb 13, 2009 | 09:03 AM
efuehrin's Avatar
Originally Posted by Stephen87
is it possible to put airbags on a truck with a 6inch suspension lift
x2 to **Pat**.
The rear block installed during a suspension lift doesn't change the distance between the leaf spring and the frame so the kit installs the same whether you have a lift or not.
Old Feb 13, 2009 | 01:29 PM
°°Pat°°'s Avatar
Originally Posted by efuehrin
x2 to **Pat**.
Yep for your model.
It's different for 04-08 model though.
I'm tired of my aal and airbag would be the solution, but i don't want to lose to much flex at the rear.
Did you see any difference in off-road performance with you airbag on?
If so, is it comparable to adding an aal? (In flex lost)
Old Feb 13, 2009 | 02:30 PM
efuehrin's Avatar
Originally Posted by °°Pat°°
Yep for your model.
I couldn't tell ya.....I don't offroad much......I go where I need to but that's about it.
Old Feb 13, 2009 | 04:08 PM
°°Pat°°'s Avatar
Ok, well thanks anyway.
And nice truck by the way
Old Feb 13, 2009 | 04:19 PM
damn no way i could fit a tank that big right there
I am gonna be doing helper air bags soon tho!
Old Feb 13, 2009 | 04:56 PM
efuehrin's Avatar
That was just a spare air bubble that I had laying around.
If you buy one that's made for a onboard setup they are a longer and skinnier.
Old Feb 13, 2009 | 05:16 PM
Yea I know, all the newer vehicles i work on have air suspensions from the factory on them. I know what you are talking about. I think im just gonna run some lines to the license plate like PimpRohr did.
Old Feb 13, 2009 | 05:17 PM
Ryanmc86's Avatar
Does the air guage in the cab come with the kit?
Old Feb 13, 2009 | 05:19 PM
efuehrin's Avatar
yeah I about went that route but I figured that since I had plenty of room under the truck I may as well use it.
Old Feb 13, 2009 | 05:20 PM
efuehrin's Avatar
NO!!!! They are proud as hell of those things too!
I think the dual controller was around $180 and the other guage was about $60 or so.
Old Feb 13, 2009 | 07:18 PM
Ryanmc86's Avatar
WOW! I liked it more before you told me that. Looks good though and looks like it handles that load pretty well.
Old Jun 30, 2009 | 07:51 PM
rsykes3's Avatar
Where did you order them?? and How much??
Thx
Old Jun 30, 2009 | 08:06 PM
06 SANDSTONE's Avatar
looks good .
Old Jun 30, 2009 | 08:35 PM
rednoved's Avatar
Nice setup!
I think your exterior is cleaner than your interior.
