Sponsored by: CARiD
Levelling Kit???
Old Jan 18, 2009 | 05:46 PM
06 BlackBeauty's Avatar
Levelling Kit???
Have a question for the experts out there, I've got a 2wd '06 F150, w/ HD payload pkg, and I want to level it out. I want to do it w/o changing tires, w/o a lift kit, and don't want to change my ride characteristics or affect my payload or towing capacity. Possible??? Suggestions???
Old Jan 18, 2009 | 05:56 PM
vogel's Avatar
just put spring spacers on it its cheap does not affect handeling or anything else. you will need to go get an allighment due to the fact your tires will toe out. you need to tell them you want to get the adj camber extentions tho. call around for prices on that cause some shops charge you out the *** for it while others do it with the allighment
Old Jan 18, 2009 | 07:05 PM
DIHLON's Avatar
You shouldn't need the adjustable camber bolts with just a level kit(or at least with an AutoSpring you don't). My camber/caster was still dead on; just the toe needed adjustment. A guy at Autospring even said he's installed thousands of these and have never had to adjust the camber/caster. If your mechanic shop said you did, you got screwed.
