Body lift question
but if you get new tires ,
watch the width ,with my BL , i had 20x9 MM951's with 6.18 bs with 35/12.5R20 Toyo Mt's and they re was like a half inch of clearance between the tire lugs and the control arms, and it rubbed on turns, bumps and what not, got pretty annoying, only cure was some new rims
honestly , i would look into new rims if you are lifting it in any way, it takes away from the lifted stance with the tires tucked in, and you would obviously have rubbing if you went with a larger width tire .
