Level Kit/AAL
Level Kit/AAL
Hey guys,
I have a 2 1/2" Leveling kit up front and I notice the back doesn't sag that much but you can notice it. I was wondering if I add a 1 1/2" AAL will the back be higher than the front again? Also, I will be putting a 6" Lift on my truck and I was wondering if I will still be able to use the LEVEL/AAL kit?
Thanks!
Thanks!
The add-a-leaf can stay in your leaf pack with your lift blocks. That isn't a problem. Depending on what type of lift kit you invest in, you may or may not be able to stack your leveling kit on top. I'm not a big fan of doing so. You are better off getting adjustable coilovers with your lift kit and then just cranking them up two inches. If you really feel that you need more lift than a 6" kit offers, then consider a body lift with it, or just get a 12" lift.
Thanks for the info.
I was looking at the Rough Country 6" Suspension lift, but I noticed that the lift had spacers in the front already. So I would assume if I removed the leveling kit and just installed the lift the truck would sit level versus having the *** end sag.
I had the same problem with my FX4 with a 2 inch spacer. I then added a leaf and now I am higher by about a half inch in the back. To me this is perfect. I would post pics but my truck looks like it took a salt bath right now.
