Sponsored by: CARiD
97-03 lift questions...
Old Jan 15, 2009 | 02:29 PM
ssj4shane's Avatar
OK WHAT CAN I FIT...
this is options im looking at...
98 f150 4x4
im running 35x12.5 now with 3"body n 2.5 keys turned
6" with keys turned 1.5"
6" with keys turned 2.5" <---aftermarkit keys...
6" with 3" body no keys turned...
AND
6" with 3" body plus 1.5" key
Old Jan 15, 2009 | 02:36 PM
blackedoutV6's Avatar
everyone here will tell you not to waste your time on aftermarket keys, apparently they will destroy your CVs due to ridiculous angles
theres a few guys running around on here that have a 3" body w/ 6" fabtechs and 38's so thats definately doable, although youd probably want to regear
one of my good buddys has a 97 w/ the 3" body and 6" fabtech w/ 35's and it still looks pretty sharp
Old Jan 15, 2009 | 04:41 PM
ssj4shane's Avatar
i know about that but thanks...
Any one have any clues about what i asked about ?
i dont wana run a body lift and i dont have a problem with cranking my keys 1.5"
.... i wana try to have a 6" lift and turn my keys 1.5" and run 36x14.5
Old Jan 15, 2009 | 05:32 PM
chiefFX4's Avatar
i dont see you running 36 x 14.5. you could run a 12.5 easily with that setup.
also, you do realize most lift kits tend to level the truck out which makes the keys useless right?
Old Jan 15, 2009 | 10:21 PM
wandell's Avatar
I'd stick with a 35x13.50 max. If you want a larger tire, add a body lift also.
Old Jan 15, 2009 | 11:13 PM
chiefFX4's Avatar
if youre already running 35s and all you really want to do is add width to the tire, no lift kit is going to help you there unless they push the wheelbase out.
if you really want to run a 36 x 14.50, take out the body lift, add the 6" suspension and then get some wheel spacers. 2" should do.
i think it would look pretty good with the body lift still on though. see what the 35s look like after the suspension lift and go from there. either way youre going to need a wheel spacer or a very small back-spacing.
Old Jan 16, 2009 | 02:47 AM
ssj4shane's Avatar
well that was just one idea i was thinking about..
im trying to find out what i can run and what i would like more...
Old Jan 16, 2009 | 12:19 PM
wandell's Avatar
I wouldn't add wheelspacers. THey will push the tires out and cause more fitment problems.
Old Jan 17, 2009 | 10:10 PM
minimonster17's Avatar
the fabtech kit for the 97-03 4x4's does increase the front track width considerably, however, i don't see you running a 14.50 tire w/o the body lift. even then, i personally would not run wider than a 14.50, as 15.50's will cause rubbing in areas you really can't do anything about.
when i had the torsion bars cranked fully w/ the stock keys on my 03, i tore cv boots on both axles, not to mention the fact that it rode rough and probably accelerated wear on the ball joints. also, especially w/ aftermarket keys, you risk stretching the torsion bars out considerably, and they will eventually sag.
i'd stay away from wheel spacers, they only cause more problems than they solve.
Old Jan 18, 2009 | 12:27 PM
ssj4shane's Avatar
I allready know about ball joint wear and cv joints....
i have had aftermarkit keys in for over a year.... maybe 2 years....
but besides all that i think im going with the 6" lift + keys 1.5 and 37x12.5
and for the rear im thinking of diching the blocks that comes with the lift and running 6" leaf springs or 5" with a little block
Old Jan 18, 2009 | 12:46 PM
4.2trimble's Avatar
you COULD fit 36x13.5 on a 6" Fabtech with the t-bars cranked, and an Add-a-leaf in the back.
Im running 36x12.5 on just a 3" body lift. But my suspension is destroyed... so its getting ripped out.
The cranking on the torsion bars is fine to level the truck but once you put oversized tires on it and start really addin stress like offroad situations your gonna wind up like me. Bend torsion bars, destroyed front axle housing, and broken lower ball joints.
If you want to run 37's get a Fabtech and leave the body lift on. theres no reason taking it off.
