Looking for help about lowering my 4X4
Hello to all:
I own a 06 F-150 FX4 S/C and i'm looking to lower it.
I know everyone wonders why i want this but it's for a good reason. One i live and work where the winters are harsh, so thats why the need for 4x4. The FX2 is what i really like, but you can't trust it in the winter here, even with extra weight in the back. And two i like the look of a lowered truck (not slammed though), and would like to get the rear in the air look gone.
My truck sits about 5 1/2" inches in the front (top of tire to wheel well) and a wopping 9 1/2" in the rear. I think maybe 1" to 2" in the front, and 3" to 4" in the rear would look great and still give me more clearance that most vehicles out there.
Most kits are for 4x2, but there are some for 4X4. Like GroundForce that has a 1"-3" kit and Belltech also. But i don't if that is enough to get the rear down. Is there anyone out there that has had this done to their truck, or know of any links with step by step pictures? It would be greatly appreciated.
u may like it and thats fine.. but honestly i dont think u can get the numbers u want...all the 4wds ive seen lowered dont sit any lower than a stock 2wd truck.. i think also u underestimate the capabilities of a 2wd truck..
I'm sure i can find a happy medium i'm sure. In total i've owned 2 2WD's and this being my 2nd 4X4. Unless your off roadin' there is no need for that height, and as for the 2WD trucks up here in the snowbelt, we call them summer vehicles. In recent years i've loaded them down with sand bags, cement blocks ect. So thats my delema, i want traction in the winter, which is why the 4X4, and the need to lower it, is for a lower *** end stylin' kinda truck in the summer. Thanks for your reply though Al
Looks good, but a little to slammed for me. I'm looking for about 3" in the front wheelwell, and 3" to 4" in the whelwell rear look. The way it sits now I have to take a run and dive into the box to get my hockey gear out! Thanks for your reply buddy. Al
Rouse? I'll have to dig that up. Thanks!
3" out of that and 4" lowering springs from a 2wd in the rear.
From what you describe, it sounds like the previous owner put a larger than stock lift block in. There should only be 2" more in the rear than the front, not 4". Here's what you should do,
Remove rear blocks and install 2wd u-bolts
Install Belltech 3" drop leaves
Install Belltech 2" drop coils and an alignment kit.
Now you should have about 3.5" of tire clearence F/R
2" coils http://www.stylintrucks.com/part.aspx?category%7ccategory_root%7c-30=Suspension&attribute_value_string%7cBrand=Bellt ech&canned_results_trigger=&partfamilyid=3340&part id=482048
3" leaves http://www.stylintrucks.com/parts.as...tfamilyid=3346
align kit http://www.stylintrucks.com/parts.as...tfamilyid=2498
2wd u-bolts http://www.trademotion.com/partlocat...07&catalogid=2
BTW you need to order 4 u-bolts, an you only need the standard duty ones, the heavy duty models are the the HD payload package and are thicker in diameter and require a new u-bolt plate and new nuts.
Man why did you go and post a pic of your Sea Doo's for? I had 2 97 GSX'S on a triton double bunk trailer. Gawd i miss them. Wife doesn't know it, but buying this truck is the first step! Then..... Sea Doo's baby!
2" coils http://www.stylintrucks.com/part.asp...&partid=482048
