Sponsored by: CARiD
I need some help with my IWE's !!!
Old Jan 3, 2009 | 01:01 AM
mattd17's Avatar
hi all, i have an 06 150screw, 5.4, 4x4, 34000 miles.... well, i was out of town last week, and a friend borrowed the truck.... it snowed a bit, so they were using the 4wd. well, when i returned, i drove down the road, popped it into 2wd, and got the famous "grind". sounded like it was on the driver side, so when i got home i checked the IWE's. sure enough, the driver side was staying locked in.
at first, i could get it to free up with a blow drier to warm it up (our temp has been between -2 and 10). so i thought it haybe had some ice inside of it. then today i took it apart and didnt find anything obvious. i verified the operation of the IWE with the engine running, and it is compressing and extending when the vacuum is applid/removed. so, i put fresh grease in it, replaced the hub o-ring, and put it all back together.
i tested it as i was driving home, and still no different !!! ARRGGGHHHH!!! well, when i got home i decided to look at the passenger side IWE also (which was completely fine 2 days ago)... well, with the engine idling in 2wd, i can pull off the vacuum line to lock the IWE, then re attach it, and try to spin the axle. i can hear a slight grinding even then just by spinning it by hand (both side do the same).
so, i went to the dealer and bought a new solenoid (mine was the "old" style, and did have some ice/water on it). well, i put the new solenoid on, blew out the lines with air, and all is still the same......
AM I MISSING SOMETHING HERE ???? i wouldnt think that both of the IWE actuators would go bad at the same time. when i had the driver IWE apart, i compressed it by hand, and then plugged the vacuum port with my finger, and it stayed compressed, so i would assume that it is fine and doesnt have any holes.
they almost act as though they are trying to dis-engage, but arent quite pulling far enough. if i get a vacuum gauge, how much should i be able to read at the inlet to the solenoid? im wondering if i am losing it somewhere.
luckily, right now we are getting a bunch more snow, so i have to use 4wd anyhow, but i would like to get this figured out soon!
Thanks for all of your input.
Old Jan 3, 2009 | 01:57 AM
FoMoCoFan17's Avatar
The default position is locked so maybe something in the ECU.
I'm not tot familiar with it but maybe you could unhook the battery for a while to reset it.
Old Jan 3, 2009 | 02:01 AM
mattd17's Avatar
its not likely that the ECU has anything to do with it.... the solenoid is working just fine. i can verify that by checking for vacuum at the hoses where they connect to the hub, and then hit the switch to 4wd, and i lose the vacuum, as designed. im wondering if i either just dont have enough vacuum, am losing vacuum somewhere, or is the IWE's are coiincendentally bad at the same time.
Old Jan 3, 2009 | 02:10 AM
Yeah, it looked you had it covered so it was just a shot in the dark.
