Lost the nuts to my AS 2.5"
Can anyone tell me what size they are? Ive had the kit for about a year and finally decided to put it on and cant find the nuts. Also is there supposed to washers?
I just received my 2" AS kit Tuesday and will be installing today. The (6) nuts are 10mm-1.5 and are nylon locknuts without flat washers. Be careful about using poor quality hardware at this location. Nuts should be grade 8.8.
RH
Finished installing my AS 2" leveling kit in about 1 hour 45 minutes, working by myself in the driveway. Only used air tools for the lower strut bolt/nut.
By the way, the proper size wrench for the lower strut bolt is 27mm, although a 1 1/16 wrench will work as well.
Tomorrow I'm off to the alignment shop
The wrench that is used on the nut is 17mm, but the stud size is 10mm - 1.50
