lifted and need more
ok so ive got the procomp stage 1 kit with 35 on kmc 20's now i need new tires and was goin to move up to 37's so i was thinking of addin some bilstein 5100's for some extra lift to clear the new tires... would that work
do they make ones for 6 inch lifts that are adjustable another 2 inches ?
correct
oooo, ok i gotcha
so you would get the ones for the stock setup, and set them to the 2 inch setting , than bolt on the pro comp spacer
If it were me, I'd just go for a 3" body lift. That way, you maintain stock balljoint and cv angles.
PS: From my experiences from lifts coils and spacers, I have become completely against any lift kit over 1"~1.5" that does not address balljoint or cv joint angles. So, if I were to go with 2" spacers, it would be a must for uni-ball UCA.
I've run body lifts on two other trucks and I'd definitely go with the 2" Bilsteins before I did a body lift on my F150. 1-2" in the front is no big deal. The Bilsteins are designed to stop down travel before anything binds. Even then, it would be cheaper to run Camburg upper arms then it would be to have someone put a body lift on, and it would look better and work better. I would hate to install a body lift on a truck that already has a 6" lift, lol.
The CV's are fine at 2", not to mention they're only turning when you're in four wheel drive.
Hey Truspeeder205,
How level does your truck sit right now with just the stage 1? I assume you have the supplied 2.5" block stacked with the stock 2" correct?
I don't see it in this thread anywhere......what model and drive is your truck?
