Sponsored by: CARiD
ball joint angles
Old Dec 16, 2008 | 10:00 PM
street fx2's Avatar
ball joint angles
Anyone who has a 1-2.5" level kit on top of a 6" suspension lift please post pictures of your ball joint angles if you have them...thanks
Old Dec 16, 2008 | 11:34 PM
°°Pat°°'s Avatar
It will look pretty much like a stock truck with a leveling kit. Because the suspension lift bring all the angle back to stock or almost.
Old Dec 17, 2008 | 10:19 PM
street fx2's Avatar
oh okay didnt no that...so once i put my lift on the angles will be fine they wont be to sharp kas im putting the level kit on before the lift
Old Dec 20, 2008 | 12:17 AM
sanddrag's Avatar
Ball joint angles
I was wondering the same. I have a 6 inch pro comp lift on my 06 f-150 and just ordered the 2 inch leveling kit. I getting ready to install it on saturday, but was nervous about the angles of the ball joints. Does anyone know if ill have any issues with my front drive line?
Old Dec 20, 2008 | 01:18 AM
jaws12's Avatar
Nope, you'll be good.
Old Dec 20, 2008 | 10:08 AM
wandell's Avatar
If you have a lift kit that uses a large spacer (like the stage one Pro COmp), I wouldn't stack a second spacer on top of it.
Old Dec 20, 2008 | 03:24 PM
street fx2's Avatar
okay but with a fabtech lift kit i should be good right
Old Dec 20, 2008 | 04:07 PM
brianjwilson's Avatar
Should be fine with the fabtech lift.
Also, if someone is uses a kit with large spacers already, you could use the Bilstein 5100 leveling shocks with them, instead of trying to stack spacers.
Old Dec 21, 2008 | 02:35 PM
travis08's Avatar
my 6inch fabtech with a 2.5 AS and im looking into a 3 inch spacer
