Sponsored by: CARiD
Alternative to rear shims
Old Dec 10, 2008 | 01:16 PM
northwestmichae's Avatar
So I cranked my torsion bars and gained about 1 11/16 lift in the front. Got Alignment. Liking it. Now my rear sits almost 1 1/2 inches lower. I looked at the pro comp shims which will give me an inch but would like to gain 2". Add a leaf is not on the budget. What would my alternatives be in the shim price range?
Old Dec 10, 2008 | 01:21 PM
azmidget91's Avatar
How about a block
Old Dec 10, 2008 | 01:22 PM
FoMoCoFan17's Avatar
You'll need blocks or springs.
How much is "shim price range"?
Old Dec 10, 2008 | 01:25 PM
The pRO cOMP shim kit is $32. 4 1/4 inch shims. A 2" block would do it? Any recommendations?
Old Dec 10, 2008 | 01:31 PM
Jditta's Avatar
Thread hijack
Fomoco, got those 5150s ordered, was it anything difficult to put them on?
End thread hijack
Old Dec 10, 2008 | 01:42 PM
My local 4wp has a universal 2" block but since it wasn't specific for my truck wasn't sure it they would work... lol anyone have and idea about these?
Old Dec 10, 2008 | 01:43 PM
Originally Posted by Jditta
Thread hijack
End thread hijack
Nope. I did it by myself, in the dark, with a flashlight and the tires on the ground.
Old Dec 10, 2008 | 01:48 PM
As long as it is the correct width and single pin design it should work fine. You could also try ebay or call Autospring.
Old Dec 10, 2008 | 04:08 PM
MikeSwt's Avatar
Dont forget to get longer U-bolts - I could only safely add 1/2. I used the Pro Comp Spacers. Gonna stop by and see my local guy to order them so I can add the other 1/2 inch
Old Dec 10, 2008 | 06:15 PM
KansasJoe's Avatar
Ford uses a 7/16 center bolt so you want a block with a 11/16 hole because all chevy's and most dodge's use 3/8 center bolts with 9/16 hole so you don't want that block.
Old Dec 11, 2008 | 12:17 AM
Thanks for the insight.. I have a feeling they are not the right part. the only one I found so far is by Skyjacker at Summit racing.
Old Dec 12, 2008 | 10:49 PM
So I ended up going with the 2" blocks. They were Fabtech blocks, replaced the U bolts with longer ones. Now the rear sits almost 1/2 inch higher than the front.. Looks killer to me and should be pretty level when I tow.. Thanks for all your insight... I'll post pics in this thread as soon as our storm passes though we are supposed to get a dumping of snow
Old Dec 13, 2008 | 12:12 AM
MikeSwt's Avatar
