Sponsored by: CARiD
4x4's..let's see your Bilstein 5100 pics (before and after)
Old Jan 4, 2009 | 03:26 PM
  #46
Nemisus's Avatar
lf22,
You would have to remove the coil from the strut/shock assembly. Than re-position the spring seat at the 2" adjustment! There are grooves in the shock body that a retaining clip holds the spring seat in place. When you re-install the spring the spring itself will set 2" higher than before..... which in turn gets you the 2" of lift! Its not a had job to do.. but without the proper tools its not an easy job either!
Hope this helps
Cheers
Nemi
Old Jan 18, 2009 | 01:56 PM
  #47
last5oh_302's Avatar
Originally Posted by Nemisus
Hope this helps!
The after is with 35" Toyo MT's
Cheers
Nem
I like the look of those FX4 wheels on an XLT
