Sponsored by: CARiD
If I add a Leaf..........
Old Nov 30, 2008 | 06:57 PM
Westcoast4121's Avatar
Question If I add a Leaf..........
If I add a ADD-A-LEAF KIT_REAR 2" LIFT and put a leveling kit on, will it sit like a 4X4? And can I still add a 7.5" Fabtech lift with the extra leaf and leveling kit?
I have a 2002 f150 2wd crew cab
Old Nov 30, 2008 | 07:57 PM
fx4 for life 79's Avatar
the 7.5" lift will sit almost as high as a 4x4
Old Dec 1, 2008 | 01:58 PM
skeeter_usaf's Avatar
Your truck sits almost 2" lower than a 4x4 so if you add those mods then yes you will be sitting as high as a 4x4. Checkout Gator crews with the mods u r talking about plus a 3" BL. I have the same setup but with the 6" suspension lift.
Old Dec 1, 2008 | 07:18 PM
Can I still add the 7.5" lift on top of the ADD-A-LEAF KIT_REAR 2" LIFT and a leveling kit? Or do I have to take it out?
Old Dec 1, 2008 | 08:06 PM
chiefFX4's Avatar
if the some of the lift is obtained through spacers up front or they use an add a leaf in the rear then dont buy the spacer or add a leaf, they will just be replaced by the lift.
