Sponsored by: CARiD
97-03 Leveling...
Old Nov 28, 2008 | 12:38 AM
NTAHORS's Avatar
97-03 Leveling...
Is there any advantage or Disadvantage to using keys to lift the front of my truck compared to just Cranking My Torsion Bars? I am not sure how the keys work.
- Corey
http://cgi.ebay.com/ebaymotors/97-03...Q5fAccessories
Old Nov 28, 2008 | 12:58 AM
brianjwilson's Avatar
They just re-index the torsion bar to give you more leverage. It is essentially cranking the torsion bars, only more. It will ride a lot more stiff, and the suspension will top out frequently on even small bumps. If they do get compressed hard, they will twist more than designed and could break (worst case) or start to sag and ride lower (most likely).
Old Nov 28, 2008 | 01:04 AM
NTAHORS's Avatar
Maybe I will just do a Body lift on the truck. But I wish I could fing a 2" kit, all I see are 3...
Old Nov 28, 2008 | 10:59 AM
wandell's Avatar
The aftermarket keys are a waste of money. They do the same thing as cranking up your torsion bars with the oem keys, except they allow you to go way to far.
Old Nov 28, 2008 | 11:25 AM
DeWayne24's Avatar
Where are these things locate on the truck?? I would like to crank mine up to level it with the rear b/c the rear is high then the front.
Old Nov 28, 2008 | 04:23 PM
wandell's Avatar
Just locate the torsion bar coming off the lower control arm and follow it back toward the cab of the truck. The adjustment key/bolt is at the end of the torsion bar where it mounts in the crossmember.
Old Dec 2, 2008 | 02:26 PM
bigswedegml's Avatar
Does raising the torsion bars weaken anything or make the truck ride differently? I have been wanting to level my 1998 F150 out so I can put a size bigger tires on and have it look good.
Old Dec 2, 2008 | 02:30 PM
mhockey9090's Avatar
as i posted earlier it will just make your ride a bit stiffer thats it and you will be to get an alignment afterwards though.
Old Dec 2, 2008 | 04:27 PM
wandell's Avatar
I agree.
Old Dec 2, 2008 | 07:57 PM
minimonster17's Avatar
the torsion bar crank will not weaken anything. it will stiffen the ride some, and may put the ball joints/ cv axle shafts at a less than ideal angle. i've offroaded my truck pretty hard a couple times, and just tore the cv boots after having the bars cranked all the way for like two years of no problems.
