Sponsored by: CARiD
Bilstein 5100s
Old Nov 20, 2008 | 10:24 PM
wreedKR's Avatar
Bilstein 5100s
Hey guys I have a stock suspension other than the 2" Autospring in the front. Can I run the Bilstein 5100s part numbers F4-BE5-C298-H0, and F4-BE5-C299-H0 on my truck?
Let me know. Thanks.
Old Nov 20, 2008 | 10:35 PM
07fx4silver's Avatar
You can only use the autospring if you have the bilsteins set for 0" (stock setting) of lift, but I would ditch the autospring and use the shocks for the 2" of lift
Also, you want part # F4-BE5-C298-H1 for the front not H0
Old Nov 20, 2008 | 10:39 PM
wreedKR's Avatar
Oh so these shocks are provide the lift in the front instead of the Autospring?
Why H1 for the front?
Old Nov 20, 2008 | 10:47 PM
Yes they have 3 grooves in the shock body and a snap ring that goes into it's place. They have 3 different settings, 0 (stock), 1" or 2".
I said H1 because that is the correct ending part #. You had all the other numbers right
In other words it's F4-BE5-C298-H1 not F4-BE5-C298-H0
Old Nov 20, 2008 | 10:48 PM
wreedKR's Avatar
I understand it might be right for my truck but whats the difference between the H0 and H1? The H0 comes up as the first correct part for my truck on the Bilstein catalog.
Old Nov 20, 2008 | 10:55 PM
To be honest I don't know, you can type both # numbers in on the Bilstein website and both will come up the same so I figure it doesn't matter
Old Nov 20, 2008 | 11:01 PM
wreedKR's Avatar
How do you replace the front shocks? Must the coil be removed?
Old Nov 20, 2008 | 11:04 PM
Yes you have to take the stock shocks out of the stock coils and install the new bilsteins in your stock coils. It's not too difficult (I installed mine) but you'll need a spring compressor as well as a few other tools and impact tools always come in handy. Although if you're uncomfortable with it, I'd probably just take it to a shop
Old Nov 20, 2008 | 11:05 PM
wreedKR's Avatar
Nah I put the Autospring in there. I got more tools than I know what to do with. I am waiting to use my new Makita impact wrench
Old Nov 20, 2008 | 11:15 PM
Wrench away then
Old Jan 18, 2009 | 09:07 PM
wreedKR's Avatar
I have a question about a pair of front Bilstein shocks I bought for my Suburban. I noticed you cannot contact Bilstein. Who should I call for help?!
Old Jan 18, 2009 | 11:14 PM
Fifty150's Avatar
Call Bilstein.
AFTERMARKET & MOTORSPORTS
HEADQUARTERS - WEST
14102 Stowe Drive
Poway, CA. 92064
1-858-386-5900
AFTERMARKET & MOTORSPORTS - EAST
293 Timber Road
Mooresville, NC. 28115-7868
1-704-663-7563
Old Jan 19, 2009 | 12:37 AM
lewdog99's Avatar
Will the bilstein 5100s work on my 98 4x4?
and can i use them with the rough country leveling kit also?
Old Jan 19, 2009 | 05:41 PM
Shepard69's Avatar
Nope. Different suspension pre 2004
Old Jan 19, 2009 | 06:39 PM
lewdog99's Avatar
what shock set up would you suggest on my 98? im stayin stock but going with a rough country leveling kit.
And an add a leaf in the rear.
