Sponsored by: CARiD
2" AS level kit
Old Nov 17, 2008 | 02:26 PM
LonestarROB's Avatar
2" AS level kit
Ok, I've purchased the tires, and hopefully later today or tomorrow, will have purchased the wheels.
Now I need the AS leveling kit. Been looking at ebay and found 2 "different" ones.
Ones Painted for $75 . And the other is Powdercoated for $85 .
Is the different coating really worth the extra $10?
Also, 2" is good right? Or should i go with the 2.5"? And why?
I have a '08 2x4 STX.
Thanks in advance.
Old Nov 17, 2008 | 02:30 PM
MrAggie1982's Avatar
If you want a level truck go with the 2.5. If you tow alot or haul then go with the 2". I have a 07 2wd and went with the 2.5 autosprings based on the recommendations of alot of members of this forum and it turned out great.
Jon
Old Nov 17, 2008 | 09:12 PM
HYPO's Avatar
You probably won't need the powder coated leveler in Texas. But, up here in Michigan where we salt the roads in winter, I figured the powder coated unit was the best way to go.
HYPO
Old Nov 17, 2008 | 10:10 PM
noblem's Avatar
personally i would go with the 2"
Old Nov 17, 2008 | 10:51 PM
Any reason why?
Old Nov 17, 2008 | 10:53 PM
wandell's Avatar
The taller the spacer, the more severe the ball joint angles. The shorter the spacer, the better the ball joint angles.
Old Nov 18, 2008 | 02:13 AM
Fifty150's Avatar
Here is the angle with my leveling kit.
Old Nov 18, 2008 | 02:14 AM
Fifty150's Avatar
This is how it looks with a Fabtech Dirt Logic Coilover.
Old Nov 18, 2008 | 09:49 AM
Havent researched those but going to take a guess and say they are probably out of my price range. :|
Old Nov 18, 2008 | 10:35 AM
milkthegoat's Avatar
04-06 usually look good with 2.5" 06-08 usually look good with 2". IMO, Most of the leveled trucks i see are like this. I have a 04 with 2.5", Its level.
Old Nov 18, 2008 | 10:59 AM
Just purchased the 2" AS kit.
Old Nov 18, 2008 | 03:20 PM
DIHLON's Avatar
Good choice going with the 2". 2.5" would have been too much.
Old Nov 18, 2008 | 05:51 PM
Silver04f150's Avatar
ill sell you my 2" AS
edit o well i guess too late
Old Nov 18, 2008 | 06:17 PM
KR-Texas's Avatar
I have an 07 FX4 and I went with a 2" AS. My front wheel well opening is about 1/2" higher than the rear wheel well, but the running boards are perfectly level.
I think you made a good choice.
FX4-Texas
Old Nov 18, 2008 | 11:36 PM
EndlessMoto's Avatar
Message sent!
