pics of 97-03 Ext Cabs lifted plz!
I bought the truck with the Fabtech lift on it, and no it didn't have a steering stabilizer. I had a 3.55LS gear ratio stock. I drove my truck on 38's with stock gears for about 3 weeks and hated every second of it. If you think there's a slight power loss with 35's, there's absolutely no power with 38's. You definitely can't drive it with overdrive on. You need the 4.88 gears if you're going to go with that big of a tire.
edit: and I was getting somewhere around 8mpg with stock gears and 38's. With the new gears I'd have to guess I'm somewhere around 12mpg (my speedo is off, so I'm not exactly sure).
heres my truck. it is a 2001 f150 with a 6" RCD lift and a 3"body lift with 35" nitto mudgrapplers
http://a133.ac-images.myspacecdn.com...229e6866fc.jpg
http://c4.ac-images.myspacecdn.com/i...1b53a01b57.jpg
My truck with a 6" Icon (DR) suspension and 6" Deaver springs w/ the factory 2" block + a 3" PA body lift on 35/12.50/17 Parnelli Jones Dirt grip radials w/ 17x10 Centerline Wolfer wheels
do you think a 37/13.50/17 would solve the problem of rubbing on the tie rods, or like a 38/13.50/17 i know you got 16's but i guess what im asking is could that problem be solved by you going from a 14.50 to a 14.00 . The only tire i could find to fit my dc-1's 17's in a 38's are irok bias and im never heard anything good about SuperSwampers.
Probably, really any tire more narrow than the one I've got would probably fix the rubbing. I love the stance these tires give though, and I can live with the rubbing. Like I said, it's really only at full lock, so if I'm pulling a U-turn or something, which doesn't happen often, I'll rub. Not to mention these tires are actually pretty cheap (They go for about 270 new) for a big mud tire.
