Sponsored by: CARiD
Loss front end after installing leveling kit
Old Oct 27, 2008 | 01:37 PM
rosmith's Avatar
Question Loss front end after installing leveling kit
I just installed a tuff country level kit on my 04 f-150 and the front ends fells and sounds loose while driving on rough roads. Any advice.
Old Oct 27, 2008 | 01:45 PM
azmidget91's Avatar
i believe the word you are looking for is loose
get an alignment
Old Oct 27, 2008 | 01:53 PM
rosmith's Avatar
will that stop the metal on metal sound that I am hearing
Old Oct 27, 2008 | 01:56 PM
azmidget91's Avatar
when are you hearing this metal on metal sound? all the time? or just turning?
Old Oct 27, 2008 | 02:04 PM
rosmith's Avatar
just on bumps.
Old Oct 27, 2008 | 02:10 PM
azmidget91's Avatar
is it a grinding sound or a clunk? check your wheels on the inside to see if they look like they were rubbing on anything
Old Oct 27, 2008 | 02:14 PM
rosmith's Avatar
its a clunking sound almost like the spring is hitting against the spacer or the spacer is hitting the criddle that the spring rested in before I installed the spacer.
Old Oct 27, 2008 | 02:19 PM
fasteddy250f's Avatar
check your sway bar. Make sure that it is tight. Sounds like the same thing that happen to my wifes 08 mustang.
Old Oct 27, 2008 | 02:20 PM
azmidget91's Avatar
most likely your upper control arm hitting the spring
Old Oct 27, 2008 | 02:23 PM
rosmith's Avatar
I'll check both and let you know what I find.
Old Oct 27, 2008 | 03:00 PM
Paralyzer's Avatar
yup upper controll arm hitting the spring is pretty common, how much of a lift did you get?
Old Oct 27, 2008 | 08:36 PM
wandell's Avatar
Yes, that is pretty common. That is why the Autospring kit is slightly offset, to eliminate this.
Old Oct 27, 2008 | 08:42 PM
JTE3097's Avatar
Ditto on the stuff said before, if that doesn't fix it... check your tierods... make sure they're serviceable.
Old Oct 28, 2008 | 03:03 PM
rosmith's Avatar
After doing some research I should have used the autospring set-up insted. This install took me and my wife uncle the whole day. After reading about the autospring this would have takin me just over an hour. I like the idea that it bolts to the strut then to the frame. I had to compress the spring and remove the top place the spacer in and so on and so on.
