Sponsored by: CARiD
Suspension Question
Old Oct 19, 2008 | 11:13 PM
BigDawg99's Avatar
Suspension Question
I have a 3" Lift on my Truck and Planning on Putting on either or 2 or 3" Body Lift in the Spring...
I haul a Camper a few times in the year and was wondering if there would be any conflicts with the amount of lift on my truck..
2004 Ford F150 Fx4
Old Oct 20, 2008 | 12:13 PM
wandell's Avatar
No, but you may want to lift the rear and inch or so higher than most people so the truck doesn't squat so bad when towing your camper. A set of airbags would be even better.
Old Oct 20, 2008 | 03:26 PM
Mr. eXtreme's Avatar
X2
AirAid modular intake tube, K&N filter, Magnaflow Exhaust, Line-X'd bed and fender wells, 2.5 Inch AS Level Kit and 3 inch AS Rear Block, 1 Mile range Viper 5900 SST remote start and alarm system, JL Audio Stealthbox, JL Audio 500/1, JL Audio 300/4, Alpine Type-R 6.5 inch components in front doors, Alpine Type-R 5x7's in rear doors, Alpine Iva-w505, LOTS of Dynamat, 15% Tinted windows, Billet Grills in factory H-bar and lower bumper.
Old Oct 20, 2008 | 10:35 PM
BigDawg99's Avatar
thanks guys..i am planning on installing the rear air Bag System to raise the rear of my truck..and to help with the Heavier Loads...
Old Oct 20, 2008 | 10:37 PM
4.2trimble's Avatar
I didnt read the whole post but are you planning on doing the BL install yourself?
If not then id recommend doing a 4" suspension lift.
Body Lift installs on the NBS trucks are rediculously expensive. just a heads up man
Old Oct 21, 2008 | 12:25 PM
BigDawg99's Avatar
thanks man...If i get the body lift installed..i am going to get it done professionally..Heard it takes alot of time when ya do it yourself....thanks for the heads up...
Old Oct 21, 2008 | 08:50 PM
4.2trimble's Avatar
you and some buddies can do it in a weekend.
Old Oct 21, 2008 | 10:50 PM
minimonster17's Avatar
its a pain getting some of the bolts out, expect to fight them every turn out. i've done two so far with only one other person, having two buddies install will not be too bad, and you'll save a good amount of cash.
