Pro Comp Stage 1 ?'s
Mercedes Tech
The ride is somewhat stiffer, but I find that it matches the front now. For what ever reason I found the lift made the front "stiffer", it could just be the added weight of tires and stearing nuckles increasing the unsprung weight. I found the back to feal to floaty, but now the ride matches. So over all a little more stiffer, but not as bad as the 06 F350 long box I had. I would recomend to re-arch to everyone, increased saftey aside (Don't stack blocks)
^^ good to know. I am dealing with that "floating" feel right now. Looking into deaver springs, but a re-arch would be much more economical. Also need to invest in some worth while shocks. Thanks for the input.
I'm running the Procomp stage 1 too.. there is a slight, maybe 1" if anything sag in the rear, I suppose a 5" block or whatever might truly level it out, but it doesn't look that bad to me.. anywho.. here's a couple pics.. kinda hard to tell considering they were taken from front angles..
you should check out the 6005 wheels.. I think they look bad azz.. lol (then again, I'm runnin on 7005)
dont worry , you ll still be the only blackout with 7005's , im putting the hulks on in a week or 2
thats a bummer the 7005s didnt work for ya.. going back to chrome wheels?
btw idnc.. check this post out, let me know whatcha think
https://www.f150online.com/forums/ge...-hub-caps.html
i sent you a few Pm's awhile back , you never responded , i was just curious , how much wider of a tire do you think you can fit with the 7005's. i only have about an inch of clearance between the tire lug and the control arm. i know its different with an actual lift. can you do me a favor and just give me an estimate. do you think you can fit a 13.5 /14.5 inch wide tire ?
sorry to hear about the center cap , mayb use some black Rtv sealant or something , im not sure though
To be honest.. wheel/tire widths and backspacing/offsets confuse the hell outta me.. I'll run out to the truck real quick and snap a few pics to see if you can figure it out.. I dunno where to begin to look with it rubbing.. I haven't had any issues yet..
brb 5 min.
brb 5 min.
