Sponsored by: CARiD
need help with leveling kit
Old Oct 2, 2008 | 12:45 PM
gunther57's Avatar
Ok here it goes, The kit is easy to put on but the problem I ran into was sway bar. I cant get the nut back on tight it spin. How do i stop this
Old Oct 2, 2008 | 12:52 PM
wandell's Avatar
Did you leave off the little rubber bushings?
Old Oct 2, 2008 | 03:50 PM
gunther57's Avatar
no the bushing is still on there. when you start tighting the nut the shaft turns and i dont know how to keep it from turning i have grabbed it with pliers and it is still turning. i think i am just going to take it to the dealership and let them mess with it
Old Oct 2, 2008 | 04:22 PM
CountryPunk's Avatar
I used a small metric socket, I think it was like a 7mm and turned the shaft rather than the nut.
Old Oct 2, 2008 | 05:21 PM
noblem's Avatar
If i am imaginging your problem right in my head, i think there is spot somewhere on the shaft that you can put a wrench on to hold it while you tighten the nut, try tookin at it real close. I think that is what your getting at
Old Oct 4, 2008 | 04:41 PM
gunther57's Avatar
Thanks for the help guys that is just what the problem was
