Sponsored by: CARiD
Lowering Kit
Old Sep 11, 2008 | 02:12 PM
ivrodriguezfx4's Avatar
Lowering Kit
Hy guys i have a 2006 fx4 supercrew 4x4, my truck its on the stock suspension i want to lower it only at the back, i mean level it as it is on the front any help.
Old Sep 11, 2008 | 02:17 PM
You can remove the rear blocks or buy lowering shackles.
Old Sep 11, 2008 | 02:50 PM
wandell's Avatar
I agree.
Old Sep 11, 2008 | 11:37 PM
ok so which way is the best and if the best way is to buy the shackles where should i get it. Another thing i am reading the forums and you guys talk about for example I drop it 4 on the back and 2 on the front what those numbers means which one should i have to take according to my lowering needs.
Old Sep 12, 2008 | 12:41 PM
wandell's Avatar
Either way will work, but removing the oem lift blocks is free.
I'm not sure what you are asking with your second question.
Old Sep 12, 2008 | 02:30 PM
thanks guys for the imputs. I mean what number should i lower the truck 1 or 2 or 3 or 4 or 5 in order to lower the truck as it is on the front. Sorry but i am new on the lowering thing. if a remove the rear bloks do i have to do anything next or that it.
apreciated.
Old Sep 14, 2008 | 05:18 PM
Dnasty777's Avatar
Those numbers are just inches. Example: someone might want a 2/4 drop that just means 2 inches drop in the front and 4 inches drop in the back.
Old Sep 14, 2008 | 07:48 PM
wandell's Avatar
Right. The purpose of a drop like a 2/4 or 4/6 is so the truck will wind up sitting level. Just like most 6 inch lift kits actually will lift the front 6 inches but only lift the rear 4 inches.
If you want your truck to sit level, then removing the oem 2 inch lift block or installing 2 inch lowering shackles should put you pretty close to perfectly level.
Old Sep 15, 2008 | 02:29 PM
Ahh ok thats what i wanted to know thanks guys for the help. Where can i get the lowering shakles for the best price and quality.
Old Sep 19, 2008 | 06:36 PM
You need 2wd U-Bolts tho (not 7700)
I always love it when i get to correct you
