Sponsored by: CARiD
Need some advice
Old Sep 2, 2008 | 05:22 PM
Jambi's Avatar
Need some advice
I have a 2005 f150 FX4 with a 2.5" spacer and I am wanting more lift. I saw that Skyjacker sells a 3" lift, that includes longer struts. Could I run the longer struts with the spacer to give me more lift? Is this possible and what problems might I run into?
Old Sep 2, 2008 | 05:58 PM
Fifty150's Avatar
APPLICATION DETAILS:
2004-2008 FORD F-150 - 2WD / 4WD
0-3" LIFT COIL OVER SHOCKS DESIGNED TO IMPROVE RIDE QUALITY AND LEVEL OUT THE FRONT OF THE VEHICLE WITH THE BACK. THESE 2.5" FULLY ADJUSTABLE AND REBUILDABLE COIL OVER SHOCKS FEATURE AN INTERNAL RESERVOIR AND ARE VALVED VEHICLE SPECIFIC FOR OPTIMUM PERFORMANCE ON OR OFF ROAD.
DESIGNED TO FIT 305/70/17 TIRES W/ 8" WIDE WHEELS WITH UP TO 5 1/4" BACKSPACE OR OTHER COMBINATIONS OF COMPARABLE HEIGHT AND WIDTH. TEST FITTING RECOMMENDED.
Kit Features
* 0-3" ADJUSTABLE LIFT HEIGHT
* EIBACH PERFORMANCE COIL SPRINGS
* IMPROVED RIDE FROM FACTORY
* BILLET AEROSPACE QUALITY COMPONENTS THROUGH OUT
* CAD PLATED FOR LONG LASTING COROSION RESISTANCE
* HIGH QUALITY PARKER BRAND SEALS AND WEAR COMPONENTS
* FOAM BUMP STOPS
* TEFLON LINED SPHERICAL BEARINGS FOR QUIETER, LONGER WEAR RESISTANCE
Old Sep 2, 2008 | 06:11 PM
mSaLL150's Avatar
you cant stack spacers ontop of those coilovers, angles will be too extreme. It will ride rough and your ball joints will fail.
Old Sep 2, 2008 | 10:59 PM
wandell's Avatar
RIght. ANd most everyone agrees that 2.5 inches is the limit without dropdown brackets before you have really excessive ball joint wear.
Old Sep 4, 2008 | 06:31 PM
Jambi's Avatar
Would I be able to notice a difference in height from the adjustable coils opposed to the spring spacer that I am currently running? Is anyone running the adjustable coil springs?
Old Sep 4, 2008 | 08:11 PM
06 SANDSTONE's Avatar
Anything over 2 1/2 '' angles start looking bad . If your already at 2 1/2 . just put on a lift kit .Don't try to Jerry rig something . I've went thru the whole leveling kit deal also . Just 2 weeks ago I lifted my truck 6in . pulling out the 2 1/2 spacers . LOL Its NEVER ENDING !!
Old Sep 4, 2008 | 10:46 PM
wandell's Avatar
The ride height will be the same with a spacer or an adjustable coilover. The replacement coilover would just give you a better shock.
