Sponsored by: CARiD
Clearance Question
Old Aug 13, 2008 | 11:13 AM
pcart23's Avatar
Clearance Question
I am a new member today and I really havent gotten a staright answer from anbody so if anyone has done this or has any comment please let me know. I have a 2003 F-150 Supercrew 4x4 with a 3 inch body lift and 33x12.50 wranglers on it right now. I want to know if I can fit a 35x12.50 on there with only minor rubbing and cutting?
Thanks,
Paul
Heres a pic of it.
Old Aug 13, 2008 | 11:45 AM
f150 rider's Avatar
Welcome to the forum I had 35s on mine with a 3" body lift but I also had 16X10' wheels with 4.5" backspacing and minimal rubbing, I think you can fit 35s but I`m not sure about the backspacing on the stock wheels, hopefully wandell (the tire and wheel King) will chime in and tell us for sure Nice truck too
Old Aug 13, 2008 | 01:07 PM
wandell's Avatar
Yes, you can fit 35x12.50's using your oem wheels. They are gonna rub the frame slightly at full steering lock. If you go to a 10 inch wide aftermarket wheel like mine, you are gonna have to trim some plastic off the front bumper's lower valance.
Old Aug 13, 2008 | 01:56 PM
pcart23's Avatar
OK thanks i was thinking about the **** Cepek DC-1 black 17x9 with Pro Comps Mud Terrain 35x12.50.
Old Aug 13, 2008 | 04:54 PM
minimonster17's Avatar
that should work fine, i'm running a 35x12.50 on a 3'' bl on my 03 4WD, and I only have rubbing at FULL lock on the frame using the oem wheels. with an aftermarket wheel, you will be ok.
Old Aug 13, 2008 | 04:59 PM
pcart23's Avatar
Great thanks!!
