Lift Problem
I recently just got my 2005 Supercrew lifted 6" with a BDS block add a leaf setup and it looks amazing but theres a problem, when i turn left or right about every quarter turn it feels as if its catching on something then releases... i called the shop about this and they said that when you lower some part on the steering that its going to happen? my truck is still drive able and doesnt rubb any where but it seems weird that this would happen becaues when it catches some times it makes my steering kinda jerky.. any suggestions would be awesome and no the tires dont rub anywhere..
http://img.photobucket.com/albums/v6...0_IMAG0135.jpg |
I'm not sure. I'd try to take a look at the steering while someone turns the wheel. It does look sweet!
go over all of your nuts and bolts that deal with the lift on my last truck i had that too after i lifted it, i put it up on a lift at the tire shop i worked at, me and a budy went over every thing and found two bolts had came loose re tourqed every thing and i was good to go
so I was gettin sick so the rubbing so I contacted bds technical support and they said the steering shaft was hitting the frame rail so took back to the shop and now drives awesome
good thing it worked out for ya. my bds lift hasnt had one problem.
how does ur truk sit w/ the bds aal? mines sittin 5/8 of a inch high in the rear now |
