Not too impressed w/ AS leveling kit
Just ordered the AS 2". Now this.
I was gonna get the 1.5 kit but the guys at autospring said that a 305/55/20 tire wouldnt fit.
Now im wondering if that statement is really true.????
Also leaves me wondering if I should have went with the BDS kit instead, which would have preloaded the spring.
I am still debating between 1.5" AS or 5100's on the 1" setting. I just want some of the rake gone, don't want it to be perfectly level.
I just put a 1.5" kit on my 2005 F150 supercab and it's perfect for me. I still maintain a little rake and the truck levels out with a load. I think a 2" would have leveled me completely but I'd definately sag with any sort of load in the bed or when towing.
I wouldn't suggest using the 2" or 2.5" without using an AAL or airbag if you're planning on hauling or towing anything more then a couple hundred pounds.
The ride is great, actually better then before - but that's due to the new 285/65-18 BFGs that I put on at the same time.
I've been running the AS 2.5" kit for about 2 year s now with no issues. It still rides like OEM. As for tire size? It all depend on the wheel size and backspacing. I know for a fact that 305/55/20's will fit with a AS. I've seen plenty of them. If you go with a 4.5" backspace, that is where you may run into issues.
Hey digg, I'm thinking about the same setup you have......the 2.5 AS kit and the AS block. Was wondering how that setup worked out? I don't mind a little rake. Do you have pics of your setup?
