Sponsored by: CARiD
Bilsteins or Leveling Kit?
Old May 12, 2008 | 06:08 PM
  #31
MeekinIt's Avatar
Originally Posted by scott1981
I did not know they made them for the rear also. A 2" lioft all around for $400 is not a bad deal and would allow you to run 35"s if you have a 4x4 model. I never did like the leveling kit idea because it just seemed like a cheap "solution" that could cause issues later down the road. The Bilsteins are about the only option I would consider
Yes you could hypothetically fit 35's in there, but your truck would have no off road capability whatsoever, plus you'd almost surely be rubbing. I have 33's on mine now and I'm glad I went with the smaller tire for extra clearance
Old May 12, 2008 | 06:33 PM
  #32
My old style Daystar kit has been doing a great job for almost 3 year's with no problem's. I still have the stock shock's with about 45k miles on them and in about 10k more miles I'm going to check out the Bilstein's. Probably the best way to go from the start if you can afford them.
Old May 12, 2008 | 09:32 PM
  #33
Galaxy's Avatar
Old May 12, 2008 | 10:33 PM
  #34
dkstone05's Avatar
I have the AS kit on my truck for about 6 months now and I really don't have anything bad to say about it. However when I put the Helo Maxx wheels with 325/60/18's on it the steering wheel wants to jerk side to side more when I go over rough sections on the road. I've heard the Bilsteins will help solve this. I plan on finding out later this summer. Also as a side note my AS kit was coated in surface rust within 3 months, guess I should've got the powder coated ones.
Old May 13, 2008 | 03:05 PM
  #35
jimc2004's Avatar
Originally Posted by JDeere7296
Sure no problem.......Sounds like you would need a block for the rears!!! I only replaced my front shocks for the time being, I don't know about the back ones since I haven't done them yet......jimc2004 must know what he is talking about since he did a write up on them.
Yea, I have all 4 shocks. I know how they work. I just want to let people know that if they are intending to lift the rear, they need to get a bigger block or add a leaf.
I started a thread with my opinion of them, as well as some input from others that have them, I think Irishfx4. We put the info out there as good F150online members, who were some of the first to use the product. I am just saying for people to do a search cause the info is out there and those that have used both the leveling kit and Bilstien 5100 leveling shocks are not going to answer every time someone asks.
And no the shocks don't lift. As someone said, the coilspring is mounted higher on the front shock to achieve the lift in the front and the rear shocks are designed for trucks lifted 0" to 1" in the rear.
Old May 13, 2008 | 03:14 PM
  #36
scott1981's Avatar
https://www.f150online.com/forums/sh...d.php?t=326855
