Sponsored by: CARiD
3" body vs. 2.5" leveling
Old Apr 27, 2008 | 11:39 PM
Jaxmasterflex's Avatar
Which would be best for fitting 35's?
Old Apr 27, 2008 | 11:44 PM
06yz250f's Avatar
if money allows do both. if you do a body lift you will still have that rake from the factory. but if you like the rake the leveling kit takes away from it. so it should just be preference on how you like it to sit. and a leveling kit should be cheaper because theres not nearly as much time needed for install.
Old Apr 27, 2008 | 11:53 PM
yea the only concern i have is being able to fit 35's with aftermarket rims with just the leveling kit. I just want the big tires of a lift but without the loss of ride and gas mileage that comes with the lift haha.
Old Apr 28, 2008 | 12:11 AM
GTRider245's Avatar
To run 35s you would have to either keep the factory rims or find a set of aftermarket that have the identical specs.
Old Apr 28, 2008 | 12:18 AM
Hash278's Avatar
I'm assuming you have a 4x4
Old Apr 28, 2008 | 12:24 PM
wandell's Avatar
I'd do both!
Old Apr 28, 2008 | 05:43 PM
yeah I have the 4x4 so would doing both provide clearance for aftermarket rims?
Old Apr 28, 2008 | 08:33 PM
wandell's Avatar
Yes, if you combine a leveling kit and a body lift you will be able to run 35's on aftermarket wheels.
Old Apr 29, 2008 | 08:26 AM
diggman08's Avatar
is there a 1-2" body lift out therre for these trucks.. that would be ideal with the 2.5 leveling kit/ a rear aal ... or for me at least.
Old Apr 29, 2008 | 04:20 PM
wandell's Avatar
No, only 3 inch body lifts are available.
Old Jun 26, 2008 | 06:16 PM
mainguy21's Avatar
can you clear the same setup if this was a 4x2? meaning aftermarket rims and 35s?
