Sponsored by: CARiD
Clearing 35's
Old Apr 24, 2008 | 09:41 PM
extremeethan's Avatar
Clearing 35's
So Im taking my lift off and want to run my 35's out, is a 2 inch kit enough to clear my 35's I know its all on back spacing and ive got I think its a nine inch wheel with 5.5 BS after looking around it seems that wheel would have the best luck at clearing them but is two inch enough. I ask for two reasons back before I had my lift I had and AS and bilsteins, but with 2.5 inchs of lift my UCA would hit on my spring at full droop making that clunking noise. I also want to know because I want to get the bilsteins again but they only have 2 inch setting, if 2 inches isnt enough Im going to go stock shocks and an AS, i dont want to put a lot into this like bilsteins and AS because I hope to sell soon just want to clear my 35s for now, let me hear your thoughts. I hope 2 inch will clear because I hated that 2.5 inch spacer clunk
Old Apr 24, 2008 | 10:45 PM
wandell's Avatar
You can fit 35x12.50's with a 2 inch leveling kit by using your OEM wheels. Also, the newer model Autospring kits have an offset design to prevent the spring touching the congrol arm.
Old Apr 24, 2008 | 10:54 PM
So a 2 inch will clear it, my wheels are very close to stock fitment wise, I had the off set design and mine still hit. have they come out with a better model in the last year or so?? I will probably just go with the bilsteins then that way I can just go with the 2 inch lift
Old Apr 24, 2008 | 10:58 PM
wandell's Avatar
I just reread your post. If you want to use a 9 inch wide wheel with 5.5 inches of bs, I doubt you are gonna fit a 35 with only 2 inches of lift.
Old Apr 24, 2008 | 11:25 PM
what do you think I need 2.5? right now ive got a ton of room to the point that I think it looks a little goofy now?? even with my wide 325 60 18s and only 2 inches of lift I never rubbed turing anyway or backing up I figured my slightly under sized half worn out 35s should fit maybe a little rub? so you think 2.0 has no chance?
Old Apr 25, 2008 | 12:49 AM
f150Lariatc's Avatar
Why ditch the lift? just wondering
Old Apr 25, 2008 | 12:59 AM
NVM, read it in the '04 section. How much are u wanting for the coils?
Old Apr 25, 2008 | 01:19 AM
in all honesty Im just sorta tired of climbing into my truck and not being able to park anywhere Im just over the lifted truck, and Im hoping it will help my gas mileage a little bit. IDK Ive had some dreams and seen some crazy lifted truck wrecks and the more I think, I think they should be out lawed, I pull up next to my sisters car all the time and think what would happen it I hit her in her car. I just dont want to be part of that lifted truck group anymore. I digress I dont want that argument I just want to clear my 35s tell I sell my truck
Old Apr 25, 2008 | 09:46 AM
wandell's Avatar
I think your best bet is to install the 35's on your oem wheels.
Old Apr 25, 2008 | 10:21 AM
OEMs are long gone another guy i saw has 34.5 inch tires on after market 20's IDK im just going to get bilsteins and try it if nothing else AS 2.5 on top (putting the bilsteins back to no lift of corse) I was hoping someone would be deff they would fit
Old Apr 25, 2008 | 10:55 AM
diggman08's Avatar
i seriously doubt youll be able to fit 35's with aftermarket wheels with only 2" as... i have a friend with 35 bfg's on his factory 20's with a 2.5"as and his rub at full lock... i can only imagine how bad yours are gonna rub.. i wouldnt do it..
(your really not going to be able to park anywhere now)
only other option i see are maybe a 3" level kit(not wise) or a 4" Rancho(wise)
Old Apr 25, 2008 | 11:27 AM
my tires are only 34.7 new and they are half worn, I dont get it I see people all the time with 35s and aftermarket wheels? Are you guys just saying I need the 2.5 lift or are you guys saying it wont clear no matter what?
Old Apr 25, 2008 | 12:53 PM
wandell's Avatar
So much depends on the wheel. Lots of people are running 35x12.50's with 2 and 2.5 inch leveling kits by using the oem 7.5 inch wide wheels with 5.5 inches of backspacing. Paw Paw is running 35's on aftermarket wheels, but I believe his wheels are 17x8's with 5.5 inches of bs, which means they only stick out 1/2 inch farther than the stock wheels. Your 9 inch wide wheels with 5.5 inches of bs are gonna stick out 1.5 inches farther than stock. You may be able to fit them, but I think you are gonna have some serious rubbing. You can try it and if they don't work it would be easy to find a set of oem wheels.
Old Apr 25, 2008 | 01:16 PM
ThumperMX113's Avatar
I agree.
Old Apr 25, 2008 | 03:59 PM
Yup 18x9 heres the specs +10mm Offset and 5 3/8" Backspace
