AAL vs. 3" rear block
i am also doin the same setup possibly.. from what i understand the aal will make the ride alot stiffer in the rear... the 3 " block will basically just lift everything up and keep the factory ride quality..
^^ agree
AAL does stiffen up the rear. depending on how tall you go, people say they don't even notice it, where others say they can't stand it, so it really comes down to personal opinion.
Towing/Hauling = AAL will help keep the rear from "squatting" .
Block= Will give your factory *like ride.
I went with the 3" block on my truck. My buddy has a 1.5" AAL and his truck does seem to ride stiffer. I don't do any hauling so I don't need the extra capacity of an AAL.
My truck rides like stock with the 3" block.
The 04's sat so high in the rear from the factory my 2 1/2" kit still leaves the rear a little higher. Just about perfect for me!
Maybe I will put it on this weekend. mine is 1/2" lower in the rear with a 2.5 kit
When I do mine I am going with the AAL. I just dont like blocks in general.
so is it that the factory rear block is larger on the early models.. if so .. im going to be replacing it anyway with a 3" so it should be the same as a 06-07 right??
or i can just go indebt and buy a 4" Rancho
I went w/ the Superlift and didn't notice a difference. They were supposed to give 1.5"-2" lift and right now, after the 2.5" AS, my rear wheel well is 1" above the front. Plus when I do load it I won't be sagging as much.
Also, I don't know that the different years really matter. Some trucks will be level w/ a 2.5" in front with nothing in the back and others wont. Just depends on a lot of variables. But that's my guess and I've been wrong almost 4 times now!
i want to get 35x12.50's but dont want them up in the wheel well.. ive seen a few truck with the 2.5 as and 3" block in rear and looks great. but thats on 06 model.. so i dunno.. if anyone has an 04 model with this lift setup please post your thoughts and pics.
