Sponsored by: CARiD
97-03 Stock Block Size
Old Apr 19, 2008 | 08:46 PM
minimonster17's Avatar
What is the size of the stock block on a 2003 F-150 4x4? I put a bl on it, some 35'' BFG's, and cranked the t-bars up all the way, and the rear end sits about 1'' lower than the front. I believe the stock block is 2'', can someone confirm that? I need to know so that i can figure out what size block i need to order to compensate for the inch difference. i don't like it when the rear sags even more when the bed is loaded. Also, is the skyjacker 3.5'' block a good one? that is the only one i was able to find on e-bay.
Old Apr 20, 2008 | 10:03 AM
wandell's Avatar
You are correct. THe oem block is 2 inches and the 3.5 inch Skyjacker block should work fine. Just make sure it comes with longer u-bolts.
Old Apr 20, 2008 | 05:09 PM
thanks, wandell!
Old Apr 22, 2008 | 10:29 PM
2" with the bumpstop horn
