Sponsored by: CARiD
I looking for this setup any body have it?
Old Apr 16, 2008 | 12:12 PM
aj_150's Avatar
Post I looking for this setup any body have it?
Any brand of six inch lift with stock fx4 wheels and 35's. I am just wondering how it would look If anyone has that setup could you post some pictures. Thank you
Old Apr 16, 2008 | 12:16 PM
Klitch's Avatar
i assume your asking 04+ body. i dont think there is any running 35" on oem wheels. i think the backspacing is wrong, but i may be wrong since i dont follow the 04-08 crowd much.
Old Apr 16, 2008 | 03:07 PM
ColonelBlue's Avatar
i have asked the same ?. but with 18s. there are a few people on here that run stocks with 35s and say they have no problem.you can run stocks with rancho 4 in and put a spacer on it to get 6 inches if you want to do that??
Old Apr 16, 2008 | 07:11 PM
Klitch's Avatar
ew. that just messes up too many angles imo
Old Apr 16, 2008 | 09:41 PM
CHUCKO1404's Avatar
check out this https://www.f150online.com/forums/sh...h+stock+wheels
Old Apr 16, 2008 | 10:21 PM
south_ms_sprcru's Avatar
i love that truck! perfect stance and height with those stock wheels...
Old Apr 16, 2008 | 10:23 PM
anyone know of any pics of 01-03 screw lifted on stock wheels with 35s? thinking that might be my next route to take...
Old Apr 16, 2008 | 10:30 PM
Shepard69's Avatar
I would be worried about excessive tire roll running the stock rims. Go wide or go home.
Old Apr 16, 2008 | 11:38 PM
you referring to rolling the sidewall off the rim? like popping a bead?
Old Apr 17, 2008 | 10:23 AM
wandell's Avatar
You are less likely to pop a bead with a narrow wheel. I think he is referring to a wider wheel will increase track width which helps offset the higher center of gravity the lift will create.
Old Apr 17, 2008 | 10:52 AM
aj_150's Avatar
i appreciae the help and thanks to whom ever posted the link to the black ford. Thats most likely what i am going to do to my truck.
Old Apr 17, 2008 | 11:26 AM
Schmidtty's Avatar
I don't think you can run stock rims on a 6" lift...the truck you are looking at is 2WD, that is why the stock rims fit. If you tried to run that same setup with 4WD you would chew the inside of your rims up with the tie rod end, trust me I did it to mine for a few day until I got my new ones on.
I think with some stock 20's you "MAY" be ok, but I don't know....
Schmidtty
Old Apr 17, 2008 | 11:44 AM
minimonster17's Avatar
i have an 03 scab fx4, black w/ a 3'' body lift and 35's. the truck looks great, but you will not be satisfied with the performance on the stock fx4 wheels, i am not. they rub at full lock on roads with a certain degree of slope. i have rubbing problems making a u turn at full lock in a two lane road. for a temp setup, i guess they're ok, south_ms_sprcru. i will take some pics today for you to look at. and yes, i am in the market right now for new wheels, have already made up my mind, and am waiting on the $$$.
