Sponsored by: CARiD
5" block with fabtech kit
Old Apr 10, 2008 | 01:40 PM
luckythirteen13's Avatar
Im gong to run a 5" block with my fabtech kit and i was wondering, will i need longer shocks then what come in the kit or will i need longer ones? if i need longer ones, how much longer?
Old Apr 10, 2008 | 01:48 PM
crash_lucky13's Avatar
i have someone going through this right now.... his rear shocks won't stay tight so we're trying to find him something that will work.. will post up if we find a good answer
Old Apr 12, 2008 | 12:32 AM
fiveoh108's Avatar
i have the rear dirt logics with a 5" block, no problems.
Old Apr 13, 2008 | 02:38 PM
GATOR CREW's Avatar
2009 F150online Truck of the Year
I have the 5" Fabtech block on my Supercrew. I hated the Fabtech shocks that came with the lift...crap IMO! I went with the Fox 2.0 Remote Reservoirs. I can get you the all the numbers(part#...length...valving...etc) that I'm running if interested, let me know
Old Apr 13, 2008 | 03:08 PM
thorherc67's Avatar
hey i need all the info on your shocks. My shocks keep coming loose and they make a ton of noise. It's annoying as hell. also how much??
Old Apr 14, 2008 | 12:05 PM
MercedesTech's Avatar
if your running the fabtech 5" block, then you need to run either their Dirt Logic rear shocks, or another long travel shock like Fox, King, or Sway A Way
Old Apr 14, 2008 | 06:09 PM
thorherc67's Avatar
damn.. what are you running, as far as shocks and rear lift blocks
Old Apr 14, 2008 | 07:04 PM
Helrazr's Avatar
Why is that?
Old Apr 14, 2008 | 07:08 PM
Me ? I am just running the regular ole "Performance" shocks and the 3" lift block.
I am 4x4 and running 35" tires, so I dont have anything "cranked" up. No need for extra lift for me, mine sits nice and level.
This is just what I have been told. Finished installing the Fabtech 6" lift on a 2wd. Used the 5" rear blocks and Dirt Logics at all four corners. No problems. Have heard of similiar problems when trying to run the 5" block and "performance" rear shocks. It has something to do with where it sits and how its valved. I really am not sure, but from what I have been told, perhaps it has to do with the "performance" shock bottoming out ? It really didn't make much sense to me either, but its what I was hearing.
Old Apr 14, 2008 | 08:09 PM
street3285's Avatar
I had a 5" block in my truck with the performance shocks and it worked fine. They never seemed to over extend.
This is what Fabtech recommended....... I used this for about 6K miles.
Old Apr 14, 2008 | 09:12 PM
There we go, I was wrong. Sorry guys, but that was my understanding.:o
Thanks for the input street. GOOD to know !
Old Apr 14, 2008 | 11:14 PM
chazf150's Avatar
When I had my lift installed it came with smaller blocks. Put the 5" blocks instead and been running with same shocks for over a year now. (Fabtech Basic Kit). So far no issues.
Old Apr 15, 2008 | 01:03 AM
alright guys, thanks for the info. i think ill just stick with the shocks that come with the kit and if they crap out on me ill upgrade then
Old Apr 15, 2008 | 08:49 PM
thorherc67's Avatar
i have a 2wd with a 5 inch block in the rear and my performance shocks bottom out and now the bushing is ruined on the inside on both the top and bottom. I am also going to add a AAL so i guess longer shocks are on the list of things to do..
