Sponsored by: CARiD
Drum to Disk Conversion.
Old Mar 31, 2008 | 11:40 AM
braupe's Avatar
Hello all,
As the title says I am cursed with rear drum brakes. I was wondering what parts do I need to convert to rear disk?
Thanks for any and all info.
Old Mar 31, 2008 | 12:13 PM
keith97xlt's Avatar
what year truck? 4wd 2wd???. i can tell you it wont be cheap. rear drums work well you just have to keep them adjusted.i have rear discs on my 250 now but.... when i had 150 id adjust then every oil change.
Old Mar 31, 2008 | 12:21 PM
braupe's Avatar
It is a 1999 2wd regular car step side 4.6 V8 Automatic. It has 3.55 gears and an open differential, and thats about all I know about the drive train.
Old Mar 31, 2008 | 07:12 PM
braupe's Avatar
Would it just be easier to buy a rear end with disk from a junk yard? Instead of locating the rear calipers and brackets etc?
Old Mar 31, 2008 | 09:49 PM
lowflyingbird's Avatar
Email me SERIOUSLY!!!
I have a 97 F150 with drums, and I bought an expedition to do a brake swap with as well as many other parts. The backing plates of the disk setup I took off the rear does not match the axle plate. If it matches yours, We can make a deal on it. I have the backing plates, emergency brakes on the plates with emergency brake cables, rotors and calipers. There are three axle backing plate bolt patterns.
One is Big Ford old= 3.150 center circle diameter,
with bolt pattern of 2.375"x3.5"
another is, Big Ford newer= 3.150.......
bolt pattern of 2.0"x3.562"
the third is= 2.56...............
bolt pattern 1.68" top to bottom
3.410"top and 3.076"bott.
I believe I have Big old. It was a 98 Expedition.
Please PM me
Old Apr 1, 2008 | 01:28 AM
braupe's Avatar
I tried to pm you but I think I am too new to the site to do so.
I would love to see if we can do that, but how can I find out what I have? Would the axle code tell me?
