Sponsored by: CARiD
Which Ones Work
Old Mar 25, 2008 | 06:58 PM
Tuchy3's Avatar
Which Ones Work
Hey, This summer I'm putting a 2.5 Ready Lift on my 4x4 supercab and wanted to get 35x12.50x18 Toyo M/T's. But which wheel works with that set up. Sorry guys, not that great with wheel specs;
- KMC XD Monster Series, Size 18X9, Bolt Pattern 6X135/5.5, Finish is Black, Off Set is -12
- KMC XD Monster Series, Size 18X9, Bolt Pattern 6X135/5.5, Finish is Black, Off Set is +18
Old Mar 25, 2008 | 08:05 PM
Dog'em's Avatar
The -12 will give you a 4.5" backspace and the +18 will give you a 5.7" backspace. With that lift and size of tires the more backspace the better, but those big mud lugs might rub on the inside upper. I've seen where others have had to put a small spacer on to keep them from rubbing. Good Luck.
Old Mar 25, 2008 | 09:01 PM
wandell's Avatar
If you drop down to a 33 inch tire you will be fine with either.
