Sponsored by: CARiD
help please! im new to lifting and trucking!
Old Mar 23, 2008 | 09:50 PM
Gatormann's Avatar
Question help please! im new to lifting and trucking!
I currently have a 07 F-150 XL 2wd and I love the look of big trucks and it would be awesome for my truck to be there. Is there any way to not feel every single bump in the road? Is there some kit (or a combination of kits) to achieve a 2 and a half inch lift and a smooth ride? Or should I go for a 4 inch kit?
Does anyone have a picture of a pair of trucks? One that has a 4 inch lift next to one that has a 2 and a half inch lift?
Also, what is the biggest size of tire I could go with this lift with no rubbing?
Thanks a ton!
Old Mar 23, 2008 | 10:30 PM
wandell's Avatar
You can install a 2.5 inch Autospring leveling kit and not affect your ride. This will allow you to fit a 33 inch tire using your OEM wheels or a wheel with similar specs. I don't know of anyone that makes a 4 inch kit for 4x2's. Pro Comp and Fabtech make 6 inch lifts for the 4x2's. These will allow you to fit 35's.
Old Mar 23, 2008 | 10:49 PM
Gatormann's Avatar
Thanks! Is there any way I can smooth out my ride? Would shocks work?
Old Mar 23, 2008 | 11:01 PM
wandell's Avatar
Most aftermarket shocks are valved stiffer than oem but a lot of members like the Bilstiens, which also feature adjustable spring preload that eliminates the need for a leveling kit.
Old Mar 23, 2008 | 11:06 PM
Gatormann's Avatar
So in other words i can do a 2.5 level/lift kit or shocks? Does the 2.5 level kit smooth out the ride a lot?
Old Mar 24, 2008 | 01:43 AM
luckythirteen13's Avatar
the leveling kit doesnt affect the ride quality at all
Old Mar 24, 2008 | 01:53 PM
fx4 for life 79's Avatar
leveling kit's ride is like stock, i have the 2.5 inch, mine is a fx4 with 33's
Old Mar 24, 2008 | 08:54 PM
mycio4791's Avatar
heres mine 3 inch leveling kit 18 inch cruiser alloy 921 c's and 33-12.50 nitto mud grapplers
[IMG][/IMG]
Old Mar 25, 2008 | 12:08 AM
Gatormann's Avatar
Originally Posted by mycio4791
heres mine 3 inch leveling kit 81 inch cruiser alloy 921 c's and 33-12.50 nitto mud grapplers
[IMG][/IMG]
Sweet truck man! That is pretty much exactally what i want to do with mine!
Where did you get your leveling kit?
Old Mar 25, 2008 | 05:10 AM
mycio4791's Avatar
i got mine at fat bobs garage on ebay just go to ebay motors and search for f150 lift kits and look for f150 3 inch aluminum leveling kit ok heres the link
http://cgi.ebay.com/ebaymotors/Ford-...em370031294104
Old Mar 25, 2008 | 11:08 AM
attworth's Avatar
A leveling kit combined with AT's or MT's is going to ride a little worse than stock. Depending on the tires you have now, most AT's are at least D range (meaning more weight capacity, stiffer sidewall, harder riding.)
My trucks rides slightly worse than stock, but still better than any older pickup I've driven.
