a grinding noise by front hub??????
I just got done installing my 2.5" leveling kit and apparantly when my spindle was released down it pulled what looks like 2 vacum lines made togather (one is a little larger than the other) loose and it plugs in behind the caliper or hub onto 2 little prongs..When I took off before I realized it was off my front hub, brake or something made a grinding noise but when I plugged it back in it quit.....Whats up with that???? Im stumped
I installed the 2.5 leveling kit and I did the exact same thing. Right side only. I drove away to hear a grinding. I got under to re-inspect my work and found the vacuum lines unhooked just like you did. Reinstalled and the noise was gone. Auto locking hubs I believe are engaged by vacuum lines.
I had a constant grinding noise in my 02 screw 4 by a few months back in 2 and 4 wheel drive I had a bad wheel bearing may be related to your prob may not be but i suggest getting the wheel bearings checked
