Sponsored by: CARiD
Cv Boots Needed Severely
Old Mar 21, 2008 | 07:08 PM
BakerF150's Avatar
My boots are ripping due to my angles on my 04 fx4 screw! ive replaced them before but they continue to rip and sling every drop of grease out. I have got to find an aftermarket boot that is softer. the factory boot is very hard and plastic like. I want a more rubbery boot. I can NOT find one anywhere. I dont care a cost. Anyone know where to find some. they can be pink green blue yellow or whatever. I dont care. Im gunna end up ruining my front end. Any suggestions????? got 2 1/2" AS and 6" fab
Old Mar 22, 2008 | 08:19 PM
BakerF150's Avatar
I guess nobody else knows where to get these boots either?
Old Mar 22, 2008 | 08:29 PM
Adam06FX4's Avatar
Registered User
my advise is remove the leveling kit or at least go down to a 2 inch.
Old Mar 23, 2008 | 12:59 AM
Hash278's Avatar
I dont think anyone knows either but I also think you should take off the leveling kit or at least go to a 1 1/2" spacer I think 2" would still be a bit much. Are you running 37's is that why you have the spacer stacked.
Old Mar 23, 2008 | 12:27 PM
BakerF150's Avatar
my tires are 36x15.50x20. They were rubbing already. i had to do some modification to the back of the fenderwell at my dads body shop to make em not rub. ive heard of leather being a possible sollution. im not sure bout using leather. i was planning on going up to 37s next time i need tires. Anyway i dont want to change my lift setup just find some boots. So many old timer mudboggers said that they used to be available but i just cant find any.
Old Mar 23, 2008 | 01:07 PM
Hash278's Avatar
Well since you dont want to lose any height just repair the boots with normal ones and look into a PA body lift
Old Mar 23, 2008 | 02:04 PM
built54's Avatar
I had the same problem when mine was lifted. I got these extra soft rubber boots, but they still ripped. your out of luck.
Old Mar 23, 2008 | 04:43 PM
JMC's Avatar
JMC
25 Year Member
Try these guys. http://www.highangledriveline.com/default.htm
Regards
Jean Marc Chartier
Old Mar 24, 2008 | 10:15 PM
BakerF150's Avatar
"Your out of luck" heck naw. Im not out of luck. Something will be done before it just ruins. where did you get your "softer rubber boots" from?
