Sponsored by: CARiD
Rear Blocks??
Old Mar 17, 2008 | 06:02 PM
cortinas's Avatar
Question Rear Blocks??
i have a 2004 f150 2wd and was wondering if there was anyway i could put a bigger block in the rear to make it taller. i already have the 2.5" spacer so would that mean i would have to go higher in the front again also? how would i do this? is there anywhere that sells this? thanks
Old Mar 17, 2008 | 06:03 PM
Russ47's Avatar
just lift it 6" and put 35's under it
Old Mar 17, 2008 | 06:47 PM
Richard D's Avatar
Do a Add A Leaf if anything.
Old Mar 17, 2008 | 07:21 PM
cortinas's Avatar
so you think an add-a-leaf is better than a block?
do they make block kits?
where can i get them and how do i level out the front once i lift the rear?
Old Mar 17, 2008 | 08:35 PM
wandell's Avatar
I don't believe your 4x2 has a lift block from the factory. If you want to lift the rear just add lift block in the size you want. You can add a 1 inch, 2 inch or 3 inch lift block. However, you are at the limit up front with the 2.5 inch leveling kit. Your only option to go higher up front is to add a complete suspension lift.
Old Mar 17, 2008 | 09:13 PM
Richard D's Avatar
Yes a add a leaf is better than a block.
Old Mar 18, 2008 | 11:07 PM
cortinas's Avatar
so i am at the limit in the front? what if i add bigger springs to the front? and then put the 2.5spacer on top of those?
Old Mar 18, 2008 | 11:22 PM
jmt0645's Avatar
not to start war, but not true. one call to Autospring CORP will reveal that a 2wd f150 can use up to a 3.5" spacer with no worse ball joint angle than that of a 4wd with 2.5 spacer. although they don't advertise it they can custom make one up to that size for a 2wd truck . i'm installing my custom ordered 3.25" spacer with 3" rear blocks (AS as well) thursday.
Old Mar 19, 2008 | 12:59 AM
cortinas's Avatar
so autospring makes a kit? the one your talking about? it has a 3" block in back and 3.25" space in front? wont this make it sit unlevel again.. and how much is this gunna run you?
Old Mar 19, 2008 | 08:00 AM
jmt0645's Avatar
its 2 seperate kits. the spacer, then the blocks. i've got about 800 pounds of tools in my toolbox so "my" truck will be level when done, however yours may not. you might do better with a 3.25"spacer up front and custom 2" block in rear. both kits together cost me ~$215.
Old Mar 19, 2008 | 03:13 PM
cortinas's Avatar
soo you think that of i get a 2" rear block and a 3.25 spacer it will sit level? what size block is on the 2wd stock from factory? 4wd?
Old Mar 19, 2008 | 07:43 PM
mbogosia's Avatar
Registered User
2Wd does not have a block from the factory. The 4WD comes with a 1 or 2 incher.
Old Mar 19, 2008 | 08:39 PM
chazf150's Avatar
Wow 3.5"AS thats pushing it. Like some one said b4 ,just do a 6" and 35`s
jmt0645 Post some pic`s when done
Old Mar 19, 2008 | 11:24 PM
jmt0645's Avatar
will do. install postponed until tuesday due to bad weather
