04 F150
04 F150
I am going to be buying a 2004 F150 4x4 extended cab soon. I plan on going with a 2.5in AS leveling kit with 1in rear blocks. I am going to put 35x12.5x17 BFG Mud Terrain KM2's and mount them on 17x9 Eagle alloy 1864 series rims. They are 4 5/8in backspace and wondering if they will work with the KM2's without any rubbing.
Originally Posted by wandell
You are gonna have to lift it higher or stick with a 33 inch tire.
Originally Posted by fireman300
Yeah but alot of the guys on this site with 04 or newer F150's have the 2.5in AS leveling kit with 35x12.5x17 and haven't had any problems with them.
Originally Posted by PawPaw
I had my 315's on 17x9 wheels w/5 inches of BS and they rubbed on the lower wheelwells. Put them on some 17x8" wheels w/ 5 1/2 inches of BS and have a lot more clearance with no rubbing. The trick is keeping the tires tucked more inside the wheelwell's. The sides of your truck will thank you as well!!
I would think you would need at least around 5" of backspacing and the tires will fit on an 8" rim. the stock rims are 7.5" and many people on here run 35x12.50 with no problems, me included.
I think the stock wheels have 5.5" of BS so I would stick as close to that as possible.
Well I have looked around and the rim that I am looking at is an Eagle Alloy 1879 that is a 17x9 with 5in of backspacing. Do you think that would be able to run or am i forced into a 17x8 with about the same backspacing?
