Sponsored by: CARiD
Stuck bolts..what to use
Old Mar 5, 2008 | 09:37 PM
faulkincanyon's Avatar
Installing a lift and have some stiff rusted bolts..anyone know of some good stuff to use?
Old Mar 5, 2008 | 09:39 PM
RJaeger's Avatar
blowtorch to will help but you gotta be careful, no idea what else would work
Old Mar 5, 2008 | 09:45 PM
c0ckac0la's Avatar
PB Blaster, denatured alcohol, TRIKE, phosphoric acid.....All will work, but PB blaster is probably the safest at preserving the finish around the work area.
If you are looking to srtip down to bare metal, try the phosphoric acid - used to etch concrete - but be careful not to let it sit over a day or it starts to dissolve the metal.
One last trick I heard about was using a slow trickle battery charger, a bar of clean steel, and a baking powder/water solution. Saw it on Trucks! No idea if it works or not though.
Old Mar 5, 2008 | 09:49 PM
where do you get the PB blaster?
Old Mar 5, 2008 | 09:59 PM
c0ckac0la's Avatar
Autozone, Kragen, etc. They have a few other products but PB Blaster should work the best. It is like wd-40 but much better. There are certain things you don't want to get overspray on, but just read the can and you'll be fine.
Old Mar 5, 2008 | 10:00 PM
crash_lucky13's Avatar
also, when you got the wrench on the bolt, do a quick rasp with a hammer in the loose direction.... that's worked more than once...just be careful and don't hurt yourself
Old Mar 5, 2008 | 10:04 PM
thorherc67's Avatar
aerosolve works well
Old Mar 5, 2008 | 10:05 PM
K_M_L_A's Avatar
blow torch,JB-80, or a good impack gun
Old Mar 5, 2008 | 10:15 PM
jonamond's Avatar
When im using a ratchet on tough bolts, I usually stick a hollow steel tube around the handle for more leverage.Always gets the job done, but might not be helpful in small areas. Then then impact gun comes in...
Old Mar 6, 2008 | 06:42 PM
f150 rider's Avatar
Blow torch, Die grinder with a metal cutoff wheel, impact wrench, and as others have mentioned THE AMAZING PB Blaster, it works phenomnal,hope this helps
